Will not allow same password?
jrsims1958
I have a CCNA lab with 3 1921 running same software; "usbflash0:c1900-universalk9-mz.SPA.157-3.M2.bin" C1900 Software (C1900-UNIVERSALK9-M), Version 15.7(3)M2, RELEASE SOFTWARE (fc2) System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1).
I am trying to find out why 2 will allow the same passwords enable and secret, but the 3rd one will not allow.  Not sure where to look to see and understand what is different between what should be identical routers.
Your helps appreciated, thanks
balaji.bandi
i would like to see what error message you get?
BB
jrsims1958
*Nov 11 16:22:50.451: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Config Wizard)conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Router(config)#ena pass cisco
Router(config)#ena secr cisco
The enable secret you have chosen is the same as your enable password.
This is not recommended.  Re-enter the enable secret.
keep both in security point not a good idea, hope you were working on some lab i guess
try secret first and password next, see if that works. (cisco tighten the security some new IOS onwards maybe works 12.X lower).
like the below order.
BB
As you can see from the first post, all 3 routers are identical to each other IOS, version. hardware.  2 will allow it but one will not. Yes they are all in the same lab, running test labs and this beginning exercise was for a single router, but I do it to all for reinforcement.
As I understand the reason behind the warning, my question is; why does it happen on just 1 of the 3?  I would like to know where to look and compare the start or run configs to see the difference, as there must be one somewhere, no matter how subtle.  So there lies the answer I am seeking, if any one can help?   That would be great!
