Cisco Switches password configuration
dwtdlt3000
Hey Everybody that visit's this Thread.
i have used a couple different models of switches and every time i set this string of commands
enable>conf t>secret>password
my switch doesn't take my password.
i think it might be because of some of the characters i use, but it allows me to use this password on this command
en>conf t>line console 0>password
i use these special characters ! _ - in the password that i set.
i'm not sure if the command
en>conf t>service password-encryption
has something to do with the special characters
so, basically what i am asking is why does my switch stop taking my password when i set the command
en>conf t>enable secret password
but i can use the same password in other locations of the switch.
i have to reset the switch every time i set that command.
thanks for an advice
Darrell Thomas
Rutherford County OIT
helpcenterus
Hello Darrell,
The problem might be related to the use of special characters in the password. When you set the enable secret password using the en>conf t>enable secret command, the password might not be accepted due to certain special characters. The service password-encryption command is unlikely to affect the acceptance of special characters, as it mainly encrypts passwords in the configuration. I would recommend checking if the special characters you're using comply with the password policy of the switch model you are using. Some switches may have restrictions on specific characters for security reasons.
Best regards
helpcenterus
Hello Darrell,
Best regards
Thank you for by he information, this definitely could be the issue.
I’m going to accept this as accepted solution.
I truly truly appreciate the reply
I am happy to have been able to help you!
