05-06-2023 07:09 AM
05-06-2023 10:30 AM - edited 05-06-2023 10:33 AM
Hello @praveen_jayawardhana
It must be some unknown reason because on my PC the devices was spread between those 2 Access Point just fine.
I might say that even in a real wireless network, clients often gets connected in Access Point far away ignoring Access Points near by.
In real world the decision made by the device algorithm should be based on the signal strenght but for some unknown reason they prefer an Access Point far away probably due signal oscilation.
If you have any other issue or doubt, you may go ahead and ask. But the behavior you saw in your simulator may not have an explanation. You can eventually close the software and open it again.
05-06-2023 07:35 AM
We need to consider that this is a simulator and not everything works as it should. But, if you share you project here, I can take a look.
You need to zip you file first.
05-06-2023 10:10 AM
05-06-2023 10:15 AM
The file is not attched. You need to zip it, otherwise it will not be attached.
05-06-2023 10:18 AM
05-06-2023 10:21 AM
Let me take a look
05-06-2023 10:23 AM
sure take your time
05-06-2023 11:19 AM
For whatever reason, it's still the same. But I agree with the information you mentioned because I have enough experience in the practical environment.
thanks @Flavio Miranda appreciate !
05-06-2023 12:34 PM
For unknown reason,
What is interface config to ap and to wlc and to router
I Need to see it
05-06-2023 12:58 PM
05-06-2023 01:01 PM
I don't have paket tracer please share here as text
