Firewall
21521561
I'm sorry if my question is so stupid. I don't know that is there any Cisco's ASA firewall just have port FE 10/100 or all of product are FE 10/100/1000 and GE? Thanks.
2 Accepted Solutions
hemohemoh
ASA firewall has different models and interfaces depending on the network size and performance requirements.
You need to check the respective model's data sheet to get those info.
Cheers!
liviu.gheorghe
Hello @21521561 ,
older models of ASA, the 5500 series, had a combination of FE (10/100 Mbps) and GE (10/100/1000 Mbps) ports. The smaller models, the 5505, had only 10/100 ports and the bigger models, the 5520, had a combination of 10/100 and 10/100/1000 ports.
As technology evolved and the throughput of the firewalls increased, the port speed increased as well. With the present models of firewalls, ports are mainly gigabit with certain models supporting 10 G ports as well.
Regards, LG
*** Please Rate All Helpful Responses ***
6 Replies 6
hemohemoh
Cheers!
Oh thanks. I will try it
Can i ask why you looking for ASA support only 10/100 mbps
MHM
I and my friends are doing some tasks about them and also arguments happened about Firewalls. Thanks.
liviu.gheorghe
Hello @21521561 ,
Regards, LG
Thank you so much. I really appreciate your answer!!!
