If some devices have SBL installed and others don’t, is there a method to upgrade both AnyConnect and SBL on the systems with SBL and only upgrade AnyConnect without trying to install SBL on systems that don’t already have SBL?
It doesn’t appear that the base install and modules will work if they are not at the same build levels.
Does the ASA support performing AnyConnect upgrades on systems with optional modules installed?
Are there any methods to filter which devices get upgrades and which don’t so that the upgrade process can go through a controlled pilot phase before mass deployment?
