Firepower Management Center with secureX orchestrator
jonasL
Hey network, i am working on a project where i need to integrate FMC in cisco secureX. Well that part worked but now i would like to use the orchestration tool in secureX to automate some workflows. I would like to block a firewall rule with it. Does any body know how to do that and how i can access the FMC api to access my firewall?
Brian Sak
SecureX orchestration need API access to your management tool for the firewall (FDM, FMC, or CDO).  CDO is easiest since it's a cloud service, like SXo, and you can run API calls against it directly.  If your Secure Firewall is being managed on-box with FDM or centrally with FMC, you'll need to either allow access from SXo to the API interface through the firewall or use SXo remote, which is the preferred method.
There's several examples out there for how to do this that can assist with building your own workflow:
Blocking Observables on Secure Firewall YT
Secure Firewall Workflows
Brian Sak
