Authentication for LAN Access
mohan786kumar
Frequent Visitor
Frequent Visitor
Can be possible integration with Azure for authenticaiton (like public redius server) or else do I need to setup locally authenication server for it.
if any recommandation that would be much appriciate.
aleabrahao
Meraki Community All-Star
Meraki does not have a direct integration with Azure AD for RADIUS authentication, you can use an intermediate NPS that is joined to Azure AD.
I am not a Cisco employee. My suggestions are based on documentation of Cisco, best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
K2_Josh
Level 4
Level 4
I have also been looking into this and have not found a managed solution that is reasonably priced to do this. And this would require local appliances if one wanted to avoid auth failures when there is an ISP failure.
This functionality currently more of a nice-to-have than mission critical on Meraki networks that I manage, so I haven't explored this deeply.
BlakeRichardson
Jumpcloud will do this and will tie in with M365 and Google workspace however it's no where near as granular as NPS.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
