TECHNICAL KNOWLEDGE
michael1999ac
Level 2
Level 2
Hi everyone, I'm new at Meraki so I'm curios about Meraki SDKs, I know there is 2 one Python based and the other Node.js based but for Python I encountered two the "meraki_sdk" and "meraki" which one of them I should be use?, both are updated? or someone is deprecadated?. For the DevAsc 200-901 certification which should I use?
5 Replies 5
Rasmus Hoffmann Birkelund
Meraki Community All-Star
You should use the "meraki" package.
Not the "meraki_sdk".
LinkedIn ::: https://blog.rhbirkelund.dk/
Like what you see? - Mark as helpful ## Did it answer your question? - Mark it as a Solution 🙂
All code examples are provided as is. Responsibility for Code execution is solely your own.
This is the one, you'd want to use; https://pypi.org/project/meraki/
michael1999ac
Level 2
Level 2
I was reading the Oficial Certificate Guide of DevAsc 200-901 and Cisco uses "meraki_sdk", do you know if that library it is deprecadated?, or in the exam both libraries will be included?
I don't know what the status of it is, but I can see that the latest published release is from 2019. So it doesn't look like it's being maintained.
Philip D'Ath
The node.js SDK doesn't get much love.
The Python SDK is the most loved.
