Conversion from Co-termination license method to Per device license method
NetDevOps
Frequent Visitor
Frequent Visitor
Hello Experts,
Meraki's default option for licensing is co-termination. So at the time of deployment, we used this method, but now we want to change the license method and use a per-device license method.
So please assist if anyone has done so before.
Brash
Meraki Community All-Star
Be aware that once converted to Per Device Licensing, you cannot convert back to co-term.
You used to be able to do it directly in the licensing section of the dashboard, however I believe it now requires support assistance.
https://documentation.meraki.com/General_Administration/Licensing/How_to_convert_a_Co-term_Licensing_organization_to_Per_Device_Licensing_organization
BlakeRichardson
I found it also requires approval from your account manager for whatever reason which I do not agree with, it should be up to the customer to decide which licensing model works best for them.
Remove the bureaucracy around this please.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
