Dark mode bugs
CMR
Meraki Community All-Star
I thought I'd start a thread about the various (often minor) dark mode bugs that still need sorting out. Please feel free to add any you find and hopefully we will get some developers reading this!
If my answer solves your problem please click Accept as Solution so others can benefit from it.
66 Replies 66
CMR
@dunky it also works for me in the same way @spaladug showed.  I am using Edge, what browser gives you the bad version?
@CMR I'm using Edge too.  I'll open a case as @spaladug suggested.
dunky
Level 8
Level 8
Org>API & Webhooks is showing white on white for me....
spaladug
Meraki Employee All-Star
@dunky I am not able to reproduce that issue. Attached pic below of how it looks for me. This is the second time you are seeing behavior inconsistent with me. Do you see the issue with other browsers or a private window in Edge? Wondering if there is some caching issue with that respective browser session.
@spaladug Looks like there is summat wrong with my Edge browser - all works fine in Chrome so I've changed to using that for the Dashboard.  Thanks
CMR
PCI report is somewhat unreadable...:
spaladug
@CMR Thanks for bringing this up. I was able to reproduce this issue and have notified engineering about the issue.
