Dark mode bugs
CMR
Meraki Community All-Star
I thought I'd start a thread about the various (often minor) dark mode bugs that still need sorting out. Please feel free to add any you find and hopefully we will get some developers reading this!
If my answer solves your problem please click Accept as Solution so others can benefit from it.
89 Replies 89
spaladug
Meraki Employee All-Star
@dunky Thanks for bringing this up. I was able to reproduce this issue and have notified engineering about the issue. Will circle back once I have an update.
CMR
Same bug as @dunky showed above, but this time on the camera settings page for the IR illuminators:
spaladug
@CMR Thanks for bringing this up. I was able to reproduce this issue and have notified engineering about the issue. Will circle back once I have an update.
spaladug
@CMR Good news as the fix for this issue was pushed out and the camera settings and what option is selected is now looking good on dark mode.
dunky
Level 9
Level 9
Same problem as previous (cannot tell which is enabled) in Wireless>Access Control in a couple of places:
spaladug
@dunky I've recently reported this issue on the Wireless -> Access Control page to engineering and they are investigating it. I'll circle back once there is an update.
spaladug
@dunky Good news is that the fix for this issue on the Wireless -> Access Control page to see which setting option is selected in dark mode has been pushed to production.
Super, thats much better, thank you
dunky
Level 9
Level 9
And they keep on coming.......
This one is at bottom of the Organization>Energy Management Page, white on white.....
Hi @dunky
Our engineering teams were able to push out a fix and this one should be fixed now. Let me know if you're still seeing it though.
@jvaldez2 Thanks, I can confirm that's now correct 🙂
dunky
Level 9
Level 9
And we still keep finding these anomolies.
This time Security & SD-WAN> Security Center
Click on most affected client - then Show this client only
You get a white bar with just the client name shown, all other info is white on white
I have selected the text below so you can see what is not visible
spaladug
@dunky I'm able to reproduce this issue. I've recently reported this issue on Security Center page, most affected client, and clicking "Show this client only" to engineering and they are investigating it. I'll circle back once there is an update.
dunky
Level 9
Level 9
And another...
Org>Policy Objects
Add a new IP to an existing group:
spaladug
@dunky I'm able to reproduce this issue. I've recently reported this issue on the Organization -> Policy Objects page to engineering and they are investigating it. I'll circle back once there is an update.
