Dashboard Problems
TODD BEERS
Level 2
Level 2
Our dashboard just started acting up. It's duplicated itself. We can't even get to a help screen, as the ? button doesn't work. Just started around 3:52 central. This happening to anyone else?
CarolineS-Meraki
Administrator
Administrator
Per status.meraki.net, this has been resolved:
”Incident resolved - A fix for the rendering and navigation issues with Meraki Dashboard has been rolled out and verified. Meraki Dashboard is now operating as expected. If you experience further issues, please don't hesitate to contact Meraki Support.”
13 Replies 13
TODD BEERS
Level 2
Level 2
Same problem here. Coworkers also reporting the problem.
CMR
Meraki Community All-Star
Yes, it looks like all of the code that normally hides elements and allows you to select items has gone AWOL so everything is just shown all at once!
Meraki Status acknowledges the problem and the fix is being deployed.
If my answer solves your problem please click Accept as Solution so others can benefit from it.
nbv1
Level 3
Level 3
Same thing here at about the same time. I didn't have time to look at it much earlier and thought it was a formatting refresh similar to the Community site here. Looking closer at it, it appears that something might've broke.
Lumen-Sebi
Community Member
same here
speacock
Community Member
Me too. Super difficult to use it this way so I guess it's time to work in Meraki tomorrow 🙂
MattyK
Community Member
Not exactly what I wanted to see when logging in this morning. looks like the Styles.css has gone missing.
Yousif89
Community Member
Checked https://status.meraki.net/ already report issue
TODD BEERS
Level 2
Level 2
Looks like they just fixed it
SergeVan
Community Member
Same here!
CarolineS-Meraki
Administrator
Administrator
This issue is now being tracked on https://status.meraki.net/ - please subscribe there for updates.
I’m going to mark this reply as the “solution”, for visibility. Will update when the issue is resolved (but status.meraki.net is the best source of info)
SWeidner11
Level 2
Level 2
I'm seeing the same issue for the past couple of hours in both Chrome and Firefox.
CarolineS-Meraki
Administrator
Administrator
