ECMS Practice Question - Jun 25th
SandroNa
Buckle Up, for a new question!
Comment below with what you think is the correct answer and remember: if you like the question or the ECMS questions initiative, leave a kudo.
See you in a week with the correct answer!
ECMS practice question
Which of the following statements is true regarding the dashboard API?
  1. Dashboard allow an administrative user to generate and maintain up to 3 API keys
  2. API Keys are generated in Organization > Configure > Settings
  3. API Access need to be enabled in Organization > Configure > Settings
  4. API keys can be retrieved from dashboard at any time after being generated
P.S. We will be sharing new practice questions weekly! If you'd like to receive updates when we do, click the "ECMS Practice" label below and then "Subscribe”
Here you can find previous questions
~~If you found this post helpful, please give it a vote up. ~~
SandroNa
CorreCCCCt! 😃
The answer is C!
5 Replies 5
kYutobi
Level 11
Level 11
C😏
Enthusiast
inderdeepsingh1
Level 11
Level 11
@SandroNa : go with @kYutobi 's Answer : "C" you next Friday !
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
wfoteping2101
Community Member
The Correct answer is C
Enable API Access
For access to the API, first enable the API for your organization under Organization > Settings > Dashboard API access.
After enabling the API, go to the my profile page to generate an API key. This API key will be associated with the Dashboard Administrator account which generates it, and will inherit the same permissions as that account. You can generate, revoke, and regenerate your API key on your profile.
Cee you next week
SandroNa
CorreCCCCt! 😃
The answer is C!
