Finding old devices...
B_97
Community Member
Hi Meraki Community,
in my warehouse, I found 3 old meraki devices:
-1xMR26 (which is end-of-sale and end-of-support)
-1xMS220-8P (which is end-of-sale)
-1xMX60 (which is end-of-sale and end-of-support)
Is there a way to reuse them (for example to set up a basic lab environment for students) buying licences and adding them to an organization?
Ryan_Miles
Meraki Employee All-Star
The MR just uses a basic (non model specific) license. So a standard LIC-MR license would work for the MR.
And as far as I can tell MX60 and MS220-8P licenses are also still purchasable.
Based on the age of the devices they'll all be limited to certain firmware versions and features. But, could still be plenty useful for a simple lab IMO.
https://documentation.meraki.com/General_Administration/Firmware_Upgrades/Product_Firmware_Version_Restrictions
Ryan_Miles
CMR
Meraki Community All-Star
@Ryan_Miles the MS220-8P runs the latest 17.1.2, it isn't dead yet!
If my answer solves your problem please click Accept as Solution so others can benefit from it.
MerakiGnome
Hi @B_97 , quick thought and might be a tad cumbersome but could you create a new Org every month and use the devices for that period, run down the trial license and then start the process over again.
Darren OConnor
https://www.linkedin.com/in/darrenoconnor
