Firmware Upgrade Auto Scheduler
betaaaa
Level 3
Level 3
Hello everyone, we get an suggestion to do firmware upgrade of our MR Appliances on May 23, 2024. as an popped up notification below :
and then we try to reschedule it to May 20, 2024 as shown below :
there are several question due to after reschedule the upgrade date, the blue popped up "Upcoming Scheduled Maintenance" still showing the scheduled upgrade will be on May 23, 2024 rather than on on May 20, 2024, even when we try to close the popped up blue notification.
So this made us confusing, when the valid/exact date this upgrade will perform ? should it on May 20, 2024 because we have already reschedule it ?
glad to hear from you all
thanks
VictorYang
The notification is not that up to date so it might still report the old date.
The date on the firmware upgrade page would be the correct date
If you found this post helpful, please give it kudos. If my answer solved your problem, click "accept as solution" so that others can benefit from it.
Philip D'Ath
Meraki Community All-Star
As indicated by your red circle, simply click the cross to get rid of that blue notification.
Your screen shot shows that it has been correctly re-scheduled.
aleabrahao
I really recommend you read the documentation.
https://documentation.meraki.com/General_Administration/Firmware_Upgrades/Managing_Firmware_Upgrades
I am not a Cisco employee. My suggestions are based on documentation of Meraki best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
VictorYang
thank you victor for your response.. just another suggestion, after re-schedule performed, the newly date of firmware upgrade date could popped up and renew/refresh the old one. Due to the popped up notification could be seen once we access the dashboard and potentially be a misleading information.. cheers
