Firmware upgrade display issue
CMR
Meraki Community All-Star
I know it's only a display bug, but please fix this 😬
If my answer solves your problem please click Accept as Solution so others can benefit from it.
jopolloc
Hi @CMR!
Just want to confirm, do you have a Support case logged for this issue already? I ask, as we want to ensure it gets recorded under the correct bug reporting process, and Engineering will want to reference the example network also (should it not be present on other dashboard organizations also).
If you found this post helpful, please give it kudos. If my answer solved your problem, click "accept as solution" so that others can benefit from it.
CMR
Thanks @jopolloc, there is now! It is case number 12412056
