Frame-Relay wrong!
qumarce-habibzadeh
Hallo
Everything I entered in the cloud was not accepted as correct. I don't know where the problem is.
Thank you in advance
R1#
interface GigabitEthernet0/0
ip address 172.16.1.1 255.255.0.0
interface Serial0/3/0
bandwidth 64
ip address 10.0.0.1 255.0.0.0
encapsulation frame-relay
frame-relay map ip 10.0.0.2 102 broadcast
router rip
network 10.0.0.0
network 172.16.0.0
R2#
ip address 172.16.0.1 255.255.0.0
bandwidth 64
ip address 10.0.0.2 255.0.0.0
frame-relay map ip 10.0.0.3 203 broadcast
router rip
network 10.0.0.0
network 172.16.0.0
R3#
bandwidth 64
ip address 10.0.0.3 255.0.0.0
frame-relay map ip 10.0.0.1 301 broadcast
router rip
network 10.0.0.0
network 192.168.1.0
Hello everyone I changed the cloud settings and connection from all levels goes smoothly. Thank you
From PC0 of R1:
Reply from 172.16.1.10: bytes=32 time=62ms TTL=126
Reply from 172.16.1.10: bytes=32 time=51ms TTL=126
Reply from 10.0.0.10: bytes=32 time=56ms TTL=126
Reply from 10.0.0.10: bytes=32 time=60ms TTL=126
From PC2 of R3:
Reply from 172.16.1.10: bytes=32 time=107ms TTL=125
Reply from 172.16.1.10: bytes=32 time=111ms TTL=125
Reply from 15.1.1.10: bytes=32 time=54ms TTL=126
Reply from 15.1.1.10: bytes=32 time=49ms TTL=126
From PC1 of R2:
Reply from 10.0.0.10: bytes=32 time=97ms TTL=125
Reply from 10.0.0.10: bytes=32 time=104ms TTL=125
Reply from 15.1.1.10: bytes=32 time=53ms TTL=126
Reply from 15.1.1.10: bytes=32 time=47ms TTL=126
13 Replies 13
@qumarce-habibzadeh
Take a look on this video, it might help you.
https://www.youtube.com/watch?v=pSD8A938P0E
Frame relay is a protocol that defines how frames are routed through a fast-packet network based on the address field in the frame. Frame relay takes advantage of the reliability of data communications networks to minimize the error checking done by the network nodes. WAN Protocols: (Playlist) ...
Hi Flavio
Thanks for your URL. I have already watched this one:
https://youtu.be/JpUveApljiw?si=NhY8faDIRzW4jH6c
It is whit only one Subnet and no point to point.
I did it 1 to 1 from Video, but is not going well.
Configure Frame Relay Static Mapping on the routers using Packet Tracer for the Cisco CCNA http://danscourses.com
Joseph W. Doherty
Have you done an Internet search for something like "frame relay configuration in packet tracer".  It should return lots of examples.
What's the source of your configuration?  I ask because I recall using subinterfaces with DLCI assignments.  That's not to say your using frame-relay maps is incorrect, in principle, although disabling inverse ARP might be required.
Later today, I may have time to load your PT file.
BTW, although I assumed your topology was ptp, possibly not as I see all 3 routers are using FR IPs in the same subnet, 10.0.0.0/8.  I guess I really need to see your PT file for the actual topology.  I also see two routers Ethernet interfaces in the same subnet 172.16.0.0/16.
Hi Joseph
Thanks for your words.
I will change the subnet
Hello all
It is now OK and every PC can connect other.
My mistake was cloud setup and I looked at Video from Flavio and correct my cloud.
Thanks once again for your support
Yep, when I finally got a chance to load your original file, the FR cloud wasn't configured correctly.  (I'm not positive it's actually correctly configured as is - much depends on what kind of logical topology you're creating, full mesh or hub and spoke.)
Your revision still has 176.16.0.0/16 on two routers' LAN interfaces.  That needs fixing.
You're using a /8 network for 3 IPs is perhaps just a bit wasteful of IP address space; probably using the /16 for a LAN subnet is somewhat wasteful too.  As you're running original RIP, suggest you use Class C networks.
Hi Joseph
You are right and the topology could be a bit better and IP addresses should be 30-bit. But for all the first tests I just used everything simply, even router RIP! And I changed the second subnet whit 172.16.0.0:-)
But I will try to do better soon!
Thanks a lot
Qu
BTW, as to using /30 networks, you cannot on the WAN, as you have 3 devices in the subnet.  You could with your LANs, but if you continue to use RIP, it's classful, so you need to use, minimally, a /24.
Hello guys, Hello Joseph!
In Packet Tracer I couldn't create a serial sub-interface, so I configured two serial interfaces on R1. In my Frame-Relay, R1 and R2 have no contact, whereas it works for R1 and R3. I don't know what I should change?
Thanks in advance
R1#
ip address 15.1.1.1 255.0.0.0
bandwidth 64
ip address 192.168.2.1 255.255.255.0
frame-relay interface-dlci 103
interface Serial0/3/1
bandwidth 64
frame-relay interface-dlci 102
clock rate 2000000
router rip
version 2
network 15.0.0.0
network 192.168.1.0
network 192.168.2.0
no auto-summary
R2#
duplex auto
speed auto
bandwidth 64
ip address 192.168.1.2 255.255.255.0
frame-relay interface-dlci 201
frame-relay interface-dlci 203
router rip
version 2
network 172.16.0.0
network 192.168.1.0
R3#
bandwidth 64
ip address 192.168.2.2 255.255.255.0
frame-relay interface-dlci 301
frame-relay interface-dlci 302
router rip
version 2
network 10.0.0.0
network 192.168.2.0
From PC0 of R1:
From PC2 of R3:
From PC1 of R2:
Edgar Benavente
Wow, this challenge brought back so many great memories 😉
All the best @qumarce-habibzadeh 🙃
Dear Edgar!
Thank you
