Insight webhook integration
ivan-brugnolli
Community Member
Webhook support for Meraki Insight seems to be a complete different configuration, when compare with the Webhooks support config in the Organization->Configure->API and Webhook. In the config page for Insight Webhooks there is no support for templates.
Are there any plans to add template support to the Insight Webhook config in the same way as currently exists in Organization->Configure->API and Webhook ?
Are there any plans to integrate Insight Webhook configuration with the Organization->Configure->API and Webhook ?
Jamiegprice15
Level 4
Level 4
This is a kind of non-answer, but I saw this from the Cisco Live presentations and hope it may help. There were decent details about webhooks in this prez.
Meraki Unleashed: Programmatic Access, Programmatic Action - DEVNET-2482 John Hartman
