08-07-2017 11:48 PM
My dashboard displays a license problem message and I'm not sure why. I bought a license for each device but Dashboard displays I am 1 license short. Any ideas?
Solved! Go to Solution.
08-08-2017 10:10 AM
You may still need to add the license information into the dashboard under Organization > License info and Add another license link.
08-08-2017 10:10 AM
08-08-2017 10:49 AM
It might just be a time issue as well. We've purchased licenses before and our rep has added the licenses to our account. It still took about a day before the error message went away.
08-08-2017 01:39 PM
The license is not tied to a particular piece of hardware. If you claim the hardware using the hardware serial number it will not automatically claim the license you purchased with the hardware. You'll need to find your license key and claim that as well. If you ordered the license and the hardware at the same time, the easiest way to claim both the hardware and the licenses is to claim using the SO number. This claims all the hardware and licenses for that order.
