meraki Saml issue
tushar01_01
Community Member
I am facing a issue where we want to add a user as meraki org admin but not able to add since the user is enrolled as saml user via okta,
But even after removing the user from saml group same error reflects,
Meraki support suggests we can user upon disabling saml settings and then enabling but that doesnt seem to be permanent fix
please suggest better approach.
aleabrahao
Meraki Community All-Star
There is no way to delete a SAML user from Meraki’s backend. Only a SAML reset clears it.
Solved: SAML SSO - user/email address removal - The Meraki Community
I am not a Cisco employee. My suggestions are based on documentation of Meraki best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
aleabrahao
tushar01_01
Community Member
Thanks for the meantime disabling the saml worked
was able to add superuser upon disabling the saml and then enabled config remain as it.
since other user are via saml
Rasmus Hoffmann Birkelund
Have you tried using email subadressing by using + keywords? Eg. user+admin@acme.org
LinkedIn ::: https://blog.rhbirkelund.dk/
Like what you see? - Mark as helpful ## Did it answer your question? - Mark it as a Solution 🙂
All code examples are provided as is. Responsibility for Code execution is solely your own.
