Org Split for EA/Sub Org
mloraditch
Meraki Community All-Star
One of my clients is acquiring from a customer who has Meraki with an EA. Only switches and MRs.
We are not assuming or expecting any transfer of licensing. We just want the hardware preferably with intact configs to ease the migration.
Despite the org split document actually saying this isn't possible yet, Support offered the seller that they could remove the EA temporarily, that would make the org co-term in a grace period, do the split, and then reapply the EA to the seller's org.
Has anyone done this or have any experience? The seller has never split before and I've done a ton, but not in this situation and they need some hand holding.
If you found this post helpful, please give it a thumbs up. If my answer solves your problem please click Accept as Solution so others can benefit from it.
RWelch-USA
Squeeze the hand gently.
Confirm with Meraki Support before proceeding, as this workaround is not officially documented and may have unforeseen consequences (prepare to do manual configs if plan goes south, have renewal licenses readily available).
