Radius using Radsec
TaniaSanchez24
Hi!
Has anybody managed to configure Meraki using RADIUS servers that only reply to radsec? I'm testing Merkai 802.1x behaviour with a Radius as a service solution that uses only radsec. Yes, I could use a proxy to overcome this but it is additional cost and hops.
I found a packet fence post where they say there is a way with Meraki if you upload the Meraki cert to your Radius server but I can't find a Meraki cert.
Network Devices Configuration Guide (packetfence.org)
Any ideas?
Thanks!
Jamie_Hessels
Frequent Visitor
Frequent Visitor
Hi Tania, did you find a solution to this?
I'm in a similar boat, trying not to use another proxy to encrypt radius packets over the net to a cloud Radius provider.
Interested to know how you went about this.
