remote syslog and snmp traps
debaker
Visitor
from the Meraki dashboard tool. i see there is an option for adding a syslog server.
IS there an option to send snmp traps also? Where is that configured?
Is there a way to do this globally or do i have to do this per device?
jdsilva
Level 11
Level 11
https://documentation.meraki.com/zGeneral_Administration/Monitoring_and_Reporting/SNMP_Overview_and_Configuration#SNMP_Traps
You need to call support and get them to enable it. You configure it globally on the Network-wide > Alerts page (visible after it's been enabled). It cannot be configured per-device.
jdsilva
Level 11
Level 11
