SAML Jumpcloud Guide
betaaaa
Level 3
Level 3
Dear All, we want to using Jumpcloud as a SSO portal before login to meraki dashboard...
Is there any clear guide for Jumpcloud and Meraki side setup?
thanks
aleabrahao
Meraki Community All-Star
Here is it 😊
https://jumpcloud.com/support/integrate-with-cisco-meraki-dashboard
I am not a Cisco employee. My suggestions are based on documentation of Cisco, best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
6 Replies 6
aleabrahao
Here is it 😊
thank you
Ryan_Miles
Meraki Employee All-Star
I followed the guide @alessandrodematos posted and got it working pretty easily.
@betaaaa If you run into any issues post back in this thread and we can assist you.
yep, it's seem pretty easy, but still lack of documentation, for jumpcloud step couldn't get as clearer than setting up on ADFS/Azure.. hopefully could have more details guides like this : https://www.miniorange.com/cisco-meraki-single-sign-on-(sso)
cheers
BlakeRichardson
@betaaaa For anything Jumpcloud related check out their support page, they have really good articles for all types of integration they support.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
BlakeRichardson
This is a bit off topic but is there likely to be SSO supported for vision.meraki.com in the future? Currently users have to access it via the dashboard and it would be a much nicer experience if users were able to login directly to the vision port via SSO.
