SSID and Network
Hi all,
I'm new with Meraki Dashboard and I would like to know if it possible to associate an existing SSID with a new Network that I have created.
Many thanks,
Maurizio
RSTOCK
Community Member
Try looking under organization-configuration sync
11 Replies 11
RSTOCK
Community Member
Philip D'Ath
Meraki Community All-Star
You can also say to create the new network by copy the existing network.
Both of the above should work. I've included a link here to a article outlining configuration sync in more detail - https://documentation.meraki.com/zGeneral_Administration/Templates_and_Config_Sync/Cloning_Network_Settings_with_Configuration_Sync
Eliot F | Simplifying IT with Cloud Solutions
Found this helpful? Give me some Kudos! (click on the little up-arrow below)
When I try to sync my new SSID to my other Wifi networks, I can only see two of them? Why can't I sync the SSID across all?
I'm trying to create a Meraki Radius SSID and have it available for all networks. I assume I can just manually create the SSID on the other networks and the users will be able to sign in at any branch office?
Philip D'Ath
Are they all "MR" access points? I'm not sure the built in access points (such as MX65W) have the same capability.
Each branch office has a MX60W. The SSID settings page allows us to setup WPA2 Enterprise with Meraki Radius for each of these sites.
We just setup a test and it appears the users have to created at each site. I hope there is a better way...
Philip D'Ath
You need a central authentication source, like Active Directory.
Do you have any centralised authentication system?
Yes sir, we have an Azure Domain Controller... So the Radius has to be setup there?
Appreciate your input!
Philip D'Ath
Absolutely. Follow this [long] guide.
https://documentation.meraki.com/MR/Encryption_and_Authentication/Configuring_RADIUS_Authentication_with_WPA2-Enterprise
Once done you can even create a group policy to deploy the WiFi settings. Users will never have to touch anything, because they will authenticate with their logged in AD credentials by default.
Awesome! You are a big deal! Smiley LOL
Philip D'Ath
That sounds like a promotion from "Kind of a big deal". Thanks.
