System Manager
SALAH1
Community Member
Bonjour, j’ai activé la licence SM sur notre tableau de bord, mais elle ne s’affiche pas dans la barre. Merci pour votre soutien
6 Replies 6
RWelch-USA
Meraki Community All-Star
Systems Manager is Cisco Meraki's Enterprise Mobility Management (EMM) solution, which includes technologies covering Mobile Device Management (MDM), Mobile Application Management (MAM), Mobile Content Management (MCM), and Mobile Identity Management (MIM).
To see a high-level overview of features available, check the official Systems Manager datasheet.
Creating an EMM Network
Before you can begin, be sure to sign up for a Dashboard account, or login to your existing account. Once you're signed in, navigate on the lefthand bar to Organization > Configure > Create network to create an EMM network. You can enroll all devices into a single network, or use multiple networks to organize your devices more granularly. If you have multiple EMM networks within your organization, you can easily move devices between them without needing to re-enroll them.
RWelch-USA
SALAH1
Community Member
le system manager ne s’affiche pas dans la barre de menu
RWelch-USA
RWelch-USA
