inter-vlan routing issue
Lalaram Raika
Level 2
Level 2
hi engineers
i have an issue with cat 9300
i have 9300 as core and downlink connected 3 cat 1300
all are with trunking ports , i have 5 vlans on core as following 192.168.1.0, 2.0, 3.0, 4.0, 5.0
each vlan have users but they are not able to ping each other
please help immidiate
17 Replies 17
Hello @Lalaram Raika ,
in order for inter-vlan routing to work, the PC's in a certain vlan should have the default gateway configured as the SVI IP address for that vlan on the 9300.
For example the vlan with subnet 192.168.1.0 should have a SVI configured on the 9300:
interface vlan 11
The rest of the SVI's are configured the same for the other vlans.
A PC in the vlan with subnet 192.168.1.0/24 would have to have the default gateway configured as 192.168.1.1
Regards, LG
*** Please Rate All Helpful Responses ***
M02@rt37
Command #ip routing configured on c9300?
Do #show vlan and #show int status and share outputs please.
Best regards
Lalaram Raika
Level 2
Level 2
Thanks @Lalaram Raika
Trunk on c1300 side are UP ?
VLANs are configured on c1300 ?
Each ports on c1300 where endusers are connected are in mode access ?
Best regards
all are fine
are the PC's in the different VLAN's able to access external resources like the Internet?
I would also check the firewall settings on the PC's - maybe disable it to test connectivity between PC's in different VLAN's.
Also, are there any access lists configured on the SVI's?
And also, can a PC in VLAN 1 for example, ping
1. it's own gateway 192.168.1.1
2. ping the default gateway of VLAN 2 - 192.168.2.1
If both pings are successful, then check the firewall config on the PC's.
Regards, LG
all are fine but still not resolved
Have you seen my reply from 2 days ago? Have you performed the connectivity tests mentioned in the reply?
Regards, LG
yes
Lalaram Raika
Level 2
Level 2
could you share your contact please so i can reach directly
Lalaram Raika
Level 2
Level 2
As i already shown you in the configuration  route is available , svi has ip , each user has gateway as svi ip and all uplink and downlink are int trunk mode, each switch has vlans and vlan1's user is reachable to gateway to another vlan's gateway
Ok @Lalaram Raika
All is good as concerned Network from your point of view ?
Have you check endpoint's side ? Windows PC ? Desactivated the Windows Firewall ?
Best regards
What about:
Can you confirm that both pings work?
Regards, LG
i think it's enough for your response but still not working
