inter-vlan routing issue
Lalaram Raika
Level 2
Level 2
hi engineers
i have an issue with cat 9300
i have 9300 as core and downlink connected 3 cat 1300
all are with trunking ports , i have 5 vlans on core as following 192.168.1.0, 2.0, 3.0, 4.0, 5.0
each vlan have users but they are not able to ping each other
please help immidiate
17 Replies 17
This confirm my theory - from a PC in VLAN1 (192.168.1.148) you are able to ping the default gateway of VLAN2 (192.168.2.1) so the inter-vlan routing works on the switch.
Check the firewall on the PC - disable it and check again.
Regards, LG
*** Please Rate All Helpful Responses ***
hello @Lalaram Raika
As I mention,
All is good as concerned Network from your point of view ?
Have you check endpoint's side ? Windows PC ? Disable the Windows Firewall ?
Best regards
