Code Exchange
Ask questions about your Developer Code Exchange submissions
Hi everyone! I’m currently learning about the Cisco Secure Access Python SDK, I want to know if using the SDK is easier than managing Cisco Secure Access manually. What are some simple tasks that beginners can try using the Python SDK?
Coding agents or network automation workflows? Please tell us how you work with Automation and AI agents, or plan to. 3 minutes, and it shapes what we build next.Survey: https://developer.cisco.com/form/nps/d9thuvgrvrnc73fc85lg
Oleksii_ by • Cisco Employee
  • 310 Views
  • 0 replies
I am able to generate a snapshot of a camera using the /devices/{serial}/camera/generateSnapshot endpoint and receive a 202 response with a snapshot url and expiry time. However when I make a GET request to the snapshot url that was returned, it give...
Elanp by • Visitor
  • 786 Views
  • 4 replies
Hello,I am using the Meraki API at https://developer.cisco.com/meraki/api-v1/overview/ to get camera information. I am looking for an endpoint that lists all of the start and end timestamps of recordings of a specific camera given a certain window of...
Elanp by • Visitor
  • 845 Views
  • 3 replies
New filtering now available for Code Exchange AI reposNow you can filter MCP servers and AI agents based on who developed them. We have two optionsDeveloped by Cisco - product-team MCP servers tend to be a more stable choice, and most of them are rem...
  • 557 Views
  • 0 replies
I noticed that when you do adevice.learn("all") or device.learn("config"), the config dictionary seems to be built strangely. It seems if a value has over 80 characters, its string is carried over to the next key. My guess is it has something to do w...
toeknee2120 by • Community Member
  • 1495 Views
  • 4 replies
I wanted to share a version of a script I recently used to analyze configuration for routers across my network. I found a route map attached to a BGP neighbor that was not defined and caused the advertisements of prefixes to be blocked, I was curious...
kkowalczyk by • Community Member
  • 1560 Views
  • 1 replies
