Try Except Final Block - Restconf PY Script
Netmart
Level 7
Level 7
When running the attached script, I am running in the following issues:
response = requests.get(ip + dn, headers=headers, auth=auth, verify=false)
NameError: name 'headers' is not defined
During handling of the above exception, another exception occurred:
Traceback:
Traceback (most recent call last):
  File "/***/TryExecptFinallyRequestsRestconf-TS.py", line 21, in <module>
    with open(filename, 'a') as f:
NameError: name 'filename' is not defined
Thanks.
@Netmart your errors are being seen in your script indicate that the variables  are not defined before they are used.
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Hope this helps.
