Error when using the module cisco.ise.system_certificate_export
INGJONATAN82
Frequent Visitor
Frequent Visitor
I am using the cisco.ise.system_certificate_exportmodule in ansible to export the certificates , but I am getting the following error :
An exception occurred during task execution. To see the full traceback, use -vvv. The error was: UnicodeDecodeError: 'utf-8' codec can't decode byte 0x9a in position 10: invalid start byte
fatal: [localhost]: FAILED! => {"msg": "Unexpected failure during module execution: 'utf-8' codec can't decode byte 0x9a in position 10: invalid start byte", "stdout": ""}
this are the version I am using :    ansible [core 2.18.0] ,  cisco.ise 2.9.5 ,  ciscoisesdk 2.2.3
This is the task i am using :
- name: Export certificate
  cisco.ise.system_certificate_export_info:
    ise_hostname: "{{ ise_host }}"
    ise_username: "{{ ise_username }}"
    ise_password: "{{ ise_password }}"
    ise_verify: no
    dirPath: "/corp/apps/network_ansible/backups/cisco_ise"
    export: "CERTIFICATE_WITH_PRIVATE_KEY"
    filename: "{{ ise_cert_name }}"
    hostName: "{{ ise_host }}"
    id: "{{ cert_id }}"
    password: "{{ ise_cert_export_pass }}"
    saveFile: true
Any thoughts  about why is not working ?
@INGJONATAN82 it would appear from your error,  the module is trying to decode a byte sequence that is not valid UTF-8, youget this error if the data being processed contains binary data or that its encoded in a different character set.
Make sure that the certificate data is being returned correctly and that its in a format that can be decoded as UTF-8, you might want to inspect the raw response from the API call.
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
