unittest - test parse vlan - issue search type
Netmart
Level 7
Level 7
I was trying to run the following test parser and it seems that there is an issue with the search type under the ConfigParserVLAN.
Please see details below.
Thanks.
python3 -m unittest test_parser_customer_vlan.py
ConfigurationParser
Accessed ConfigParser Module
E
ERROR: test_parse_cust_vlan (test_parser_customer_vlan.TestParse)
Traceback (most recent call last):
File "/cisco/test_parser_customer_vlan.py", line 11, in test_parse_cust_vlan
parsed_vlan = cp.parseCustomerVlan(customer_name)
File "/cisco/ConfigParserVLAN.py", line 12, in parseCustomerVlan
allCustomerSubInterfaces = re.search(intPattern, self.deviceConfig)
File "/usr/lib/python3.10/re.py", line 200, in search
return _compile(pattern, flags).search(string)
TypeError: expected string or bytes-like object
Ran 1 test in 0.001s
FAILED (errors=1)
import unittest
import re
from ConfigParserVLAN import ConfigurationParserVLAN
class TestParse (unittest.TestCase😞
  def test_parse_cust_vlan(self😞
     print ("ConfigurationParser")
     cp = ConfigurationParserVLAN()
     customer_name = "CUSTOMER_A"
     expected_vlan = 100
     #self.assertEqual(list, type(parsed_vlan))
     self.assertEqual(expected_vlan, parsed_vlan)
if __name__ == '__main__':
    unittest.main()
 ConfigParserVLAN.py
#Regular Expression Module re
import re
class ConfigurationParserVLAN:
 with open("config.txt") as deviceConfig:
  def parseCustomerVlan(self, customerName😞
      print ("Accessed ConfigParser Module")
      intPattern = (
          r"interface GigabitEthernet0\/0\. ([0-9]+)\n encapsulation "
          r"dot1Q [0-9]+\n ip vrf forwarding %s"
          % (customerName)
      return int(allCustomerSubInterfaces.group(1))
@Netmart looks like you need to read the contents of the config.txt file into a string before calling re.search. Try using the open() function's read() method.
Hope this helps
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
