Update existing project in cisco devnet
dahanuma
I wanted to update https://developer.cisco.com/codeexchange/github/repo/Appdynamics/nginx-monitoring-extension/ to the latest information available in the corresponding Github https://github.com/Appdynamics/nginx-monitoring-extension.
I want both github and Devnet to be in sync
For example in the Devnet
Version
Name Version
Extension Version 2.2.1
where as in Github :
Version
Name Version
Extension Version 2.2.2
Jesus Illescas
There is no automatic refresh, but I'll ping the team to see what they can do
5 Replies 5
@dahanuma you can do into the admin section of your profile, find the submission https://developer.cisco.com/user/dashboard#codex and once loaded, on the code exchange resync this, it will pull all new changed from GH into Code Exchange.
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
@bigevilbeard I dont see any submissions under https://developer.cisco.com/user/dashboard#codex  . This is a existing Project in Devnet . I just want to sync and i am not the admin (some one else added the project)
@dahanuma arh ok .. that a bit of an issue then. I do not know if Code Exchange does an automated refresh. If not one of the code exchange admin at Cisco would need too.
Jesus Illescas
Oleksii_
I've resynced the repo manually
