Second Level Domain for Expressway MRA
dryliciouz
I need to verify 1 question.
We are deploying Expressway MRA for 2 different environment.
1st is for Development / UAT for Testing Purpose, 2nd is actual Production environment.
The question that i want to ask is both must run together concurrently, we may not be able to use same domain.
Whether we can use a second-level domain for the UAT?
For example, UAT will use test.example.com as the domain & Production will be using example.com as domain.
Is that possible?
Thanks & Regards
Jaime Valencia
Yes, the MRA configuration guides cover you can have multiple domains in the same expressway, have you reviewed such documentation?
java
if this helps, please rate
Vinod.s
Level 3
Level 3
Yes you can .... But everytime user has to switch his domain to login via MRA 1 OR MRA 2 setup .
