WebEx CUCM User Sync Problem
Maheer Brown
Level 3
Level 3
Hi Guys
I have an issue where End Users configured on CUCM will not auto sync with WebEx.
Ive tried both LDAP End Users and manual End Users and have the same problem.
Groups and Roles are configured correctly and it ws working before but then suddenly stopped.
M
Maheer Brown
Level 3
Level 3
Users take 6 months to purge from WebEx
So if you rename a user domain etc then the users will not sync after 6 months
Maheer
Hi Singh
The configuration seems to be correct but its still not syncing.
Any other ideas?
M
Have you fixed that ? I have also the same issue .
Maheer Brown
Level 3
Level 3
Maheer
