cdnadmin
Community Member
This document was generated from CDN thread
Created by: Roger Pardo on 07-10-2010 07:06:01 PM
Is there a way to download the audio console and put it on a CD, in order to install it on a PC on a closed network?
Thanks in advance for any feedback on this.
Best Regards,
Roger
Subject: RE: audio console
Replied by: Håkon Sandsmark on 19-10-2010 11:39:45 PM
Hi Roger,
You can download the attached build.xml file and run the "ant" command from the folder where you placed the file. All the necessary files are then packed into a single file called audio-console.jar which you can put on your CD.
PS: This build.xml file is hard coded for the current version of the Audio Console.
Let me know if you have any problems.
Håkon
