Collaboration Knowledge Base
Intro to Ansible
Good Documentation
The Great Selenelion
>> View previously featured conversations <<
Knowledge Base Articles
This document was generated from CDN thread Created by: Mayank Sharma on 12-01-2009 03:56:36 PM Hi again,Is there a way to access the device information like Serial Numbers? I could not find any table that stores that.I am using CUCM 6.1.Thanks,MaxSu...
cdnadmin by • Community Member
  • 11959 Views
  • 4 comments
  • 11 Helpful votes
This document was generated from CDN thread Created by: deniz caglar on 09-09-2008 01:24:25 PM Hi all,I need to use * and # characters to complete getting dtmf input. As i read it is achieved by setting termchar property. By default it is #, but i wa...
  • 866 Views
  • 1 comments
This document was generated from CDN thread Created by: Greg Worm on 11-10-2011 03:41:24 PM I am looking to use an inline DTMF grammar for variable length digits within a form object.  I am looking for the syntax that would work with Gateway Version ...
  • 11488 Views
  • 17 comments
This document was generated from CDN thread Created by: null on 27-10-2003 06:33:18 PM Hi,I am trying to using a custom library (Jscape Inet factory) to send emails through an smtp server with audium 3.3 with call session data. The code runs fine and...
  • 913 Views
  • 1 comments
This document was generated from CDN thread Created by: Binny Mathew on 07-08-2012 09:37:19 AM Hi, I am implementing tone masking in my application and am using a vxml property "bargeinType" and setting it to "hotword" where i need it and the same is...
  • 1479 Views
  • 1 comments
This document was generated from CDN thread Created by: David Requena on 14-05-2013 12:36:33 PM I seem to be unable to properly shutdown my provider. There always remain a couple dangling threads running ([LogFileTraceWriteThread] and [Thread-10]). I...
  • 1747 Views
  • 1 comments
  • 1 Helpful votes
Top Contributors
