cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: Cory Wright on 05-05-2006 07:54:04 PM
Janine wrote and wanted to know the following:
Why is it that the cisco confidence levels "elementname.value_confidence" come back between 0-100, not 0-1.0? Is that a bug or a cisco thing? It's weird, because I still have to set the confidence cutoff value to be between 0-1.0, but the return value for the confidence is 0-100.
I thought it would be useful to others to see the answer if someone here could answer it.
Cory
Subject: RE: Cisco CVP Confidence level question
Replied by: Vance Vagell on 11-05-2006 10:46:06 PM
Hi Janine,
Could you please confirm which voice browser you encountered this issue on?
Please note that the "value_confidence" element data variable of Form elements is derived from the name$.confidence value on the voice browser. Section 2.3.1 of the VoiceXML 2.0 spec indicates that this value should always be returned as 0.0-1.0:
[quote:ab480e5827]name$.confidence
The confidence level for the name field and may range from 0.0-1.0. A value of 0.0 indicates minimum confidence, and a value of 1.0 indicates maximum confidence.[/quote:ab480e5827]
However, we would like to know which voice browser you have seen this on so that we can attempt to reproduce the issue and investigate it further.
Vance
