cdnadmin
Community Member
This document was generated from CDN thread
Created by: Ganesh K on 09-06-2010 03:10:31 PM
We are integrating Cisco Voice Portal with Nuance, from CVP application calling the web application which is running on Nuance server and everytime if there is a change in application it expects us to reload the VXML Gateway. Until unless you reload the VXML Gateway the changes doesn't effect.
Is there any other way to do this without restarting the VXML Gateway.
Subject: RE: Cisco VXML Gateway
Replied by: Tieying Xuan on 10-06-2010 02:26:03 AM
Try
 application voice load ServiceName
Not sure if I got your question.
