cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: Ivan Ivanov on 02-11-2010 11:28:49 AM
Hello.
What are the jitter and network delay allowably for equipment Tandberg?
Subject: RE: jitter and network delay
Replied by: John Regan on 24-11-2010 01:31:01 PM
Hi Ivan,
The text below is taken from TANDBERG and H323 document which you can find here http://www.tandberg.com/support/dl.php?id=517&dir=White_Papers&fn=D5030507%20TANDBERG%20and%20H323.pdf
Jitter and Latency
Latency can be defined as the time between a node sending a message and receipt of the message by
another node.  The TANDBERG systems can handle any value of latency, however, the higher the
latency, the longer the delay in video and audio.  This may lead to conferences with undesirable delays
causing participants to interrupt and speak over each other.
Jitter can be defined as the difference in latency.  Where constant latency simply produces delays in
audio and video, jitter can have a more adverse effect.  Jitter can cause packets to arrive out of order or
at the wrong times.  TANDBERG systems can manage packets with jitter up to 100ms; packets not
received within this timeframe will be considered lost packets.  If excessive packet loss is detected, the
TANDBERG systems will make use of IPLRTF (see document D50165, TANDBERG and IPLR, for more
information) or downspeeding (flow control) to counteract the packet loss.
The C-series endpoint utilizes a dynamic jitter buffer that can increase in value depending on the
performance of the network.  To minimize introduced latency, this buffer will begin at 20ms and continue
to 100ms if sufficient packet loss or jitter is occurring.  Additionally, the C-series endpoints supports RTP
time stamping into the audio packets in order to help reduce lip sync issues that may occur over an
H.323 call.
To further improve lip sync with high resolution images (including XGA, w720p and other high resolution
video formats), the C-series endpoints support dynamic buffering of video packets in an attempt to place
information on the wire as fast as possible.  Without this functionality, the endpoint would attempt to
maintain a consistent packet size when placing the information on the wire, which would result in video
being buffered internally to ensure that the entire packet could be filled prior to transmission.  This
potential buffering created a potential lip sync issue at the far end of the H.323 call as the time between
the actual capture of the visual image and placing the information on the wire was not a constant and,
therefore, the far end system cannot adjust for any time differences between the arrival of the video
information and the arrival of the audio information.
The endpoint will now, by default, not buffer the high resolution images prior to transmission, which will
ensure a constant time delta between the arrival of the video and audio information to the far end,
allowing for an adjustment as necessary and improved lip sync.  This change in behavior, though, can
cause the endpoint to send out consecutive packets that have a relatively large difference in size.  For
example, one packet can come out at 1400 bytes while the packet behind that can be sent out at 800
bytes followed by a 1200 byte packet and so on.  Some QoS configurations improperly handle the large
adjustments in packet size, thereby dropping packets within the QoS buffer and causing packet loss in
the call.  If, for any reason, it is necessary to reduce the impact of this behavior, it can be done through
the API command ‘xConfiguration Network [1..1] TrafficControl Mode: <On/Off>’.  When this setting
is ‘On,’ the endpoint will buffer the traffic in order to provide more consistent packet sizing; ‘Off’ (default)
will not buffer any video internally.
I hope this answers your questions.
John Regan
Product Specialist (Endpoints)
CDO Escalations
Cisco
