cdnadmin
Community Member
This document was generated from CDN thread
Created by: Jason Shaffer on 07-07-2013 08:49:04 AM
Hi Cisco Dev Team,
Trying to set feedback expressions on the MCU, but it keeps on giving a fault code of 103, malformed parameter:  "This is given when a parameter of the correct name is present, but cannot be read for some reason; for example the parameter is supposed to be an integer, but is given as a string.The parameter in question is given in the fault string in the format "malformed parameter - parameter_name".
Here is an example POST we are doing to the MCU:
 1$events = "<param>
 2     <value>
 3      <struct>
 4       <member>
 5        <name>events</name>
 6        <value>
 7         <struct>
 8          <member>
 9           <name>participantConnected</name>
10           <value>
11           <boolean>true</boolean>
12           </value>
13          </member>
14         </struct>
15        </value>
16       </member>
17      </struct>
18     </value>
19     </param>";
20
21  $request_param = array( "receiverURI"=>$server_host, "events" => $events );
22  $method_name = "feedbackReceiver.configure";
23  $result = $mcu_ctrl->sendCommand($method_name, $request_param)
Are we missing something or is this formatted properly?  Any assistance would be great.
Thanks!
-jason
Subject: RE: MCU HttpFeedback Issue
Replied by: Thomas Bonhomme on 08-07-2013 07:11:50 AM
Hi Jason,
Your code is not complete, but I think the problem is with your "events" structure.
In order to configure a feedback expression on the MCU, I would try to send something like that:
 1    <methodCall>
 2        <methodName>feedbackReceiver.configure</methodName>
 3            <params>
 4                <param>
 5                    <value>
 6                        <struct>
 7                            <member>
 8                                <name>authenticationUser</name>
 9                                <value><string>admin</string></value>
10                            </member>
11                            <member>
12                                <name>authenticationPassword</name>
13                                <value><string></string></value>
14                            </member>
15                            <member>
16                                <name>receiverURI</name>
17                                <value><string>http://tms1:8080/RPC2</string></value>
18                            </member>
19                            <member>
20                                <name>receiverIndex</name>
21                                <value><int>-1</int></value>
22                            </member>
23                            <member>
24                                <name>events</name>
25                                <value>
26                                    <struct>
27                                         <member>
28                                            <name>participantConnected</name>
29                                            <value><boolean>true</boolean></value>
30                                        </member>
31                                    </struct>
32                                </value>
33                            </member>
34                        </struct>
35                    </value>
36                </param>
37            </params>
38    </methodCall>
Hope that helps!
Thomas
Replied by: Thomas Bonhomme on 08-07-2013 09:54:58 AM
Thanks for the feedback, Jason and I'm glad that works now.
Happy coding!
Thomas
Replied by: Jason Shaffer on 08-07-2013 09:33:15 AM
Hi Thomas,
Thanks so much for the prompt, reliable support!
Seems to work like a champ!...
Take care,
-jason
