cdnadmin
Community Member
This document was generated from CDN thread
Created by: Edwin Vos on 27-02-2013 09:46:30 AM
Is there an API for Cisco Unity Connection that gives access to the reporting within Unity Connection? What we are planning to do is the following: - create a scheduler ourself that has access to the reporting and let's you run the desired report for a particular period. So we need to be able to acess the predefined reports and give in the date range using the API. When reading the documentation I didn't find any clue on this.
lindborg
Not an API but I put several of the more interesting built in reports for Unity Connection as scripts for the new Python Scripting Host which you can find on its home page here:
http://www.ciscounitytools.com/Applications/CxN/PythonScriptingHost/PythonScriptingHost.html
The reporting data can only be pulled from the database via ODBC - the Scripting host makes that very easy - check out the example scripts and the training videos and such on the home page - might be just what you're looking for.
As a side note, the Scripting host even allows you to schedule scripts (reports) and have the results emailed to you directly - very handy.
