M02@rt37
My aim is to connect my CUBE to a remote CUBE (G711u) with SIP-TLS control (SIPs) and encrypted the RTP payload (SRTP)
Between my CUBE and my CME (G729), I want only SIP and RTP.
source: https://www.cisco.com/en/US/docs/ios-xml/ios/voice/cube_proto/configuration/15-2mt/voi-srtp-rtp-int.html
LICENCE:
Even if cme-srst and cube licence are activated, I need also to activate the technology-package securityK9 in order to have access to all srtp commands.
CONTROL:
The Cisco Unified Border Element supports SIP To SIP calls with TLS. CUBE can be configured at both the global and dial-peer levels for allowing TLS to establish secure sessions between two CUBE.
In order to check the feature information for SIP TLS support on CUBE please refer to this cisco documentation:
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube/configuration/cube-book/voi-cube-sip-tls.pdf
On my plateform I've got one CA (Windows 2012R2) and I use SCEP protocol in order to certified my CUBE with the CA.
SCEP documentation: https://www.cisco.com/c/en/us/support/docs/security-vpn/public-key-infrastructure-pki/116167-technote-scep-00.html
Step 1:
Generate on CUBE the rsa key:
crypto key generate rsa general-keys label CUBE modulus 2048
Step 2:
Create the pki trustpoint-CA on CUBE
crypto pki trustpoint ca-server
 enrollment mode ra
 enrollment url http://@ip-SRV-CA:80/certsrv/mscep/mscep.dll
 serial-number
 revocation-check none
 rsakeypair CUBE
Step 3:
Collect the Root CA certificate in the CUBE's flash memory:
crypto pki authenticate ca-server
Step 4:
Check the receipt of the Root CA certificate thanks to the serial number in comparaison with the CA server.
sh crypto pki certificates verbose ca-server
CUBE-A#sh crypto pki certificates verbose ca-server
CA Certificate
  Status: Available
  Version: 3
  Certificate Serial Number (hex): 1B8EEAF0AFFE78A94C54BAAA45A13329
  Certificate Usage: Signature
Step 5:
Enroll the CUBE:
crypto pki enroll ca-server
Step 6:
The CUBE is waiting for a challenge. Then, on your CA server go to:
http://localhost/certsrv/mscep_admin/ (You will need Domain Administrator account)
Then you can copy the challenge (password's lifetime=60 minutes)
Step 7:
CUBE configuration:
voice service voip
 allow-connections sip to sip
 no supplementary-service sip handle-replaces
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  bind control source-interface Loopback0
  bind media source-interface Loopback0
  session transport tcp tls ***** global configuration or on dial-peer *****
  registrar server expires max 600 min 60
sip-ua
 crypto signaling default trustpoint ca-server ecdsa-cipher
 transport tcp tls v1.2
On the dial-peer with the remote CUBE enter:
voice-class sip url sips
On my plateform the remote CUBE has got the same configuration. The same CA server is used. If you want to test with two differents CA server don't forget to put the Root CA certificate of the Remote CA server by creating another pki trustpoint:
crypto pki trustpoint Remote-CUBE
 enrollment url http://@ip-Remote-CUBE:80
 SRTP:
You need first to configure the dspfarm profil in security mode:
dspfarm profile 1 transcode security
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 codec g729r8
 maximum sessions 5
 associate application CUBE
With LTI method we don't need to register the Secure Universal Transcoder to the CUBE, with SCCP method you need it, refer to the cisco documentation:
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube_proto/configuration/12-4t/cube-proto-12-4t-book/voi-srtp-rtp-int.pdf
Then, we have to configure the dial-peers on our CUBE:
Dial-peer between CUBE and my local CME:
dial-peer voice 29702 voip
 description DP-INBOUND-FROM-LOCAL-CME
 incoming called-number 2970.$
srtp fallback
 no vad
dial-peer voice 29710 voip
 description DP-OUTBOUND-TO-LOCAL-CME
 destination-pattern 2971.$
 session protocol sipv2
 session target ipv4:10.10.10.10
 srtp pass-thru
 no vad
Dial-peer between CUBE and Remote CUBE:
dial-peer voice 2970 voip
 description DP-OUTBOUND-TO-REMOTE-CUBE
 destination-pattern 2970.$
 session target ipv4:30.30.30.30
 srtp
 codec g711ulaw
 no vad
dial-peer voice 2971 voip
 description DP-INBOUND-FROM-REMOTE-CUBE
 incoming called-number 2971.$
 srtp
 codec g711ulaw
 no vad
On the voice service voip menu:
voice service voip
 mode border-element license capacity 100
 srtp fallback
 sip
  srtp-auth sha1-80 (SHA-32 by default).
We can also configured srtp-auth on the dial-peer:
voice-class sip srtp-auth sha1-80
TEST:
With CAIN ou Wireshark you can check the SIP-TLS connection and if the RTP is well encrypted between the two CUBE.
On your CUBE:
#show call active voice brief
