NSO NETCONF NED Building Issue
tchowdhu@cisco.com
I am trying to create NSO NETCONF NED with ned builder and I am seeing this error
module openconfig-platform-port 2018-01-20
 build-error
module openconfig-platform-transceiver 2018-11-25
 build-error at line 557: the node is config, but refers to a non-config node 'type' defined at yang/openconfig-platform@2019-04-16.yang:302
module openconfig-terminal-device 2019-11-28
 build-error at line 1477: the node is config, but refers to a non-config node 'type' defined at yang/openconfig-platform@2019-04-16.yang:302
any idea how to fix this?
tchowdhu@cisco.com
Looks like I got it worked by deselecting openconfig modules and any other module depends on openconfig modules.
