VMANAGE (API) : PROBLEM to add USER GROUP
giviney
I have the next script (in python) and when i try to add USER GROUP with POST i can´t do that
def add_group():
print("\nSe cargara el grupo ctl-team....")
url_group = https://{{vmanage}}:{{port}}/dataservice/admin/usergroup
with open('grupo_list.json') as list:
      group=json.load(list)
response = requests.post(url=url_group, headers=header,verify=False,data=json.dumps(group))
if response.status_code == 200:
       print('Se cargo de forma correcta el grupo "list"')
else:
      print('Error al cargar el grupo "list"' + str(response.text))
      exit()
-i recieve the following message
Error al cargar el grupo "list"{"error":{"message":"create user group request failed","details":"User group creation permission check failed.","code":"USERGR0003"}}
-I am using user with rol netadmin.
-When i used the same scritp to add USER GROUP in other VAMANGE , it worked ok , without problems.
-When i tried to do the same (add USER GROUP)  wtih POSTMANA , i received the same error message (attach screen)
Which could be the problem? any advice?
thanks you
Giancarlo Villarreal
@giviney suggest asking this in this community for response https://community.cisco.com/t5/sd-wan-and-cloud-networking/bd-p/discussions-sd-wan
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Hope this helps.
thanks  for your recommendation @bigevilbeard , i am going to try luck in that community.
