Problems with session management on CSC/Cisco website (SSO related)
Peter Paluch
Dear friends,
I have come across an issue regarding the single sign-on (SSO) used throughout the Cisco website and CSC that starts to be increasingly annoying:
  1. I visit the CSC and log in to respond to some thread. Then I start responding to a post.
  2. During the response, I need to consult the technical documentation, configuration guides or other documents on the Cisco website. So in another tab of my browser, I visit the Cisco website and do my searching/browsing.
  3. At some point, the Cisco website recognizes that I am already logged into the CSC and starts producing URLs with the /partner/ component in it (e.g. in Search results). Clicking on such URL will cause me to be redirected to the login page again. This is the first issue - why do I have to log in again since I am already logged in and the SSO is supposed to take care of that?
  4. Okay, I enter my credentials again, get logged in, access the necessary document, and then I return back to my opened post on CSC, finish it and submit it. KABOOM - the CSC swiftly informs me that I am unauthorized to perform that action, losing my answer in the process! Logging into the Cisco website (as described in the Step 3) obviously invalidates my current session on CSC! I need to login again to the CSC (until I do that, it considers me as guest again but when I click on the Login link, I suddenly get logged in without entering my credentials) and, well, write my answer anew. Sometimes, a part is salvageable but usually it's only a small fragment.
Would it be possible to correct this behavior? I've lost quite some time rewriting my lost answers.
Best regards,
Peter
15 Replies 15
Hello Sudheer,
Thank you very much! I have had some break from participating on the CSC for a couple of weeks because of other work engagements. I will test the functionality and if I stumble across a problem I will certainly let you know.
I am very thankful to you for your kind ongoing support!
Best regards,
Peter
