Nexus9000 guestshell iperf3 values issue
Dennis Xitlaly
Hi All!
I have one problem related to running GuestShell on Nexus 9000 I managed to successfully run guestshell and install iperf3. But when i start measuring channel bandwidth, it shows tiny values, the hundreds of kilobytes, while the real channel is 25g The switches run with the same software version:
Software
BIOS: version 07.69
NXOS: version 9.3(8)
BIOS compile time: 04/07/2021
NXOS image file is: bootflash:///nxos.9.3.8.bin
Hardware
cisco Nexus9000 C93180YC-EX chassis
Intel(R) Xeon(R) CPU @ 1.80GHz with 24631952 kB of memory.
Processor Board ID FDO250617ZH
GuestShell versions are the same:
show guestshell detail
Virtual service guestshell+ detail
State : Activated
Package information
Path : /isanboot/bin/guestshell.ova
Application
Installed version : 2.10(0.0)
Description : Cisco Systems Guest Shell
Signing
Key type : Cisco release key
Method : SHA-1
Licensing
Version : None
Resource reservation
Disk : 1000 MB
Memory : 500 MB
CPU : 10% system CPU
Attached devices
Type Name Alias
Disk _rootfs
Disk /cisco/core
Serial/shell
Serial/aux
Serial/Syslog serial2
Serial/Trace serial3
show virtual-service list
Virtual Service List:
Name Status Package Name
guestshell+ Activated guestshell.ova
Example of iPerf3 measuring:
[root@guestshell admin]# iperf3 -c 10.10.10.2
Connecting to host 0.10.10.2, port 5201
[ 4] local 10.10.10.1 port 29030 connected to 10.10.10.2 port 5201
[ ID] Interval Transfer Bandwidth Retr Cwnd
[ 4] 0.00-1.00 sec 106 KBytes 868 Kbits/sec 36 4.24 KBytes
[ 4] 1.00-2.00 sec 45.2 KBytes 371 Kbits/sec 32 9.90 KBytes
[ 4] 2.00-3.00 sec 45.2 KBytes 371 Kbits/sec 23 4.24 KBytes
[ 4] 3.00-4.00 sec 65.0 KBytes 533 Kbits/sec 20 4.24 KBytes
[ 4] 4.00-5.00 sec 39.6 KBytes 324 Kbits/sec 17 2.83 KBytes
[ 4] 5.00-6.00 sec 41.0 KBytes 336 Kbits/sec 19 4.24 KBytes
[ 4] 6.00-7.00 sec 43.8 KBytes 359 Kbits/sec 20 4.24 KBytes
[ 4] 7.00-8.00 sec 43.8 KBytes 359 Kbits/sec 12 4.24 KBytes
[ 4] 8.00-9.00 sec 42.4 KBytes 347 Kbits/sec 16 4.24 KBytes
[ 4] 9.00-10.00 sec 46.7 KBytes 382 Kbits/sec 20 4.24 KBytes
[ 4] 0.00-10.00 sec 519 KBytes 425 Kbits/sec 215 sender
[ 4] 0.00-10.00 sec 471 KBytes 386 Kbits/sec receiver
iperf Done.
[root@guestshell admin]# iperf3 -c 0.10.10.2 -R
Reverse mode, remote host 10.10.10.2 is sending
[ 4] local 10.10.10.1 port 29032 connected to 10.10.10.2 port 5201
[ 4] 0.00-1.00 sec 70.7 KBytes 579 Kbits/sec
[ 4] 1.00-2.00 sec 43.8 KBytes 359 Kbits/sec
[ 4] 2.00-3.00 sec 46.7 KBytes 382 Kbits/sec
[ 4] 3.00-4.00 sec 28.3 KBytes 232 Kbits/sec
[ 4] 4.00-5.00 sec 58.0 KBytes 475 Kbits/sec
[ 4] 5.00-6.00 sec 36.8 KBytes 301 Kbits/sec
[ 4] 6.00-7.00 sec 58.0 KBytes 475 Kbits/sec
[ 4] 7.00-8.00 sec 38.2 KBytes 313 Kbits/sec
[ 4] 8.00-9.00 sec 46.7 KBytes 382 Kbits/sec
[ 4] 9.00-10.00 sec 48.1 KBytes 394 Kbits/sec
[ 4] 0.00-10.00 sec 506 KBytes 415 Kbits/sec 181 sender
[ 4] 0.00-10.00 sec 475 KBytes 389 Kbits/sec receiver
maybe someone has run into the same issue?
configuration of the switch and QoS i am talking about.
BB
9 Replies 9
balaji.bandi
i do not believe you get accurate results when you using guestshell with iperf3 as per my testing.
i use external rasberry Pi or any other device server and client passing the traffic using switch got better results.
BB
Sure, that's obviously, iperf3 on GuestShell isn't about ideal accuracy results. But in this case something strange happens, huge discrepancy between real (25g) and measured bandwidth (<1 Mbits)
its all depends on config, the maximum i am able to achieve was 1Gb as i remmember correctly.
BB
could you clarify, please, which config you are talking about?
BB
Thanks for your response!
In my case, these two switches are a part of the test stand and the only traffic that runs is iperf traffic between these nexuses. So there is no competitive traffic
i use external box for testing p2p device rather iperf using container.
BB
Dennis Xitlaly
By the way, I managed to find the bottleneck. It was COPP policy that dropped iperf traffic to the control plane of the switches. Upon making an alteration in the policy, I managed to measure about 300 Mbits/sec tops on 25 Gig links. I suppose it's a question of policy again. For test goals it's OK, but of course this configuration isn't for production.
BB
