ACI: Create l3extDefaultRouteLeakP with terraform
giom87
I'm trying to create a l3extDefaultRouteLeakP in Cisco ACI with terraform without results.
This is a json example:
            "l3extDefaultRouteLeakP": {
              "attributes": {
                "always": "no",
                "annotation": "",
                "childAction": "",
                "criteria": "only",
                "extMngdBy": "",
                "lcOwn": "local",
                "modTs": "2021-11-25T15:21:22.873+00:00",
                "rn": "defrtleak",
                "scope": "l3-out",
                "status": "",
                "uid": "15374",
                "userdom": ":all:common:"
is there an example i can use?
Thank you!
Marcel Zehnder
Can you post the corresponding terraform code? Which path do you specify in the aci_rest resource?
Ruben Cocheno
@giom87
Has this been resolved?
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
