aci_rest ansible and token APIC-cookie
cyberpea
 Is it possible using the ansible aci modules to login once and get the token and pass the cookie on subsequent aci_rest tasks? The goal is to avoid having to login and logoff with userid/password on aci_rest calls that have loops.  Is this possible?
Ruben Cocheno
@cyberpea
Yes, you can reuse the token
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
Ruben Cocheno
@cyberpea
