APIC-EM PnP Application upgrade issue
javerill
I needed to reset my APIC-EM 1.5.0.1368 instance due a misconfiguration.
After running the "reset_grapevine" command from the CLI, the system restarts with PnP version 1.4.3.1009.  I'm trying to upgrade this to version 1.5.0.211, but it doesn't appear to work properly.
Any ideas?
Thanks in advance,
Jason
It appears that the 3rd time was the charm!
I was able to install the new version of the PnP application after the last reset_grapevine.
On to test IWAN!
5 Replies 5
aradford
Hi Jason,
did you go into Admin-> App Management and check to see if you could disable old version and either enable or upload the new version?
BTW, I assume you destroyed disks when you did a reset_grapevine?
I have tried to disable / enable the app.  that didn't make any difference.
I did destroyed the disks when I did the reset_grapevine.
This is a test instance, so I can do pretty much anything to the system short of reloading from the ISO.  I can do that as well, but need to drag in another team to rebuild the VM.
Just for good measure, I re-ran the reset_grapevine, making sure to destroy the disks.
I'll post the results once the system rebuilds.
On to test IWAN!
